Gm all, I have a problem, when I extract a file it tells me that the file is too large to be extract, do I want to know how to I extract this fine and do I just extract it to the disc? Thank you.
Results 1 to 11 of 11
Need more information.....like what you mean by extract, do you mean copy or move...location of file...type of file...computer specs...what it is you are actually trying to do?????Originally Posted by arileysr2bits
ok files download as winrar archive, and i would have to extract the winrar so when i extract a movie it says it's too large so the question is how do i extract it to put it on a disc or do i extract it to the disc, it's not letting me extract it to burn it as a data file so how can i do it thx
Yup ... deffinately sounds like a fat32 problem ...
The solution ... convert your hdd to ntfs then you will be able to extract the file -
convert my what? never heard of neither, ok the file i'm trying to extract is 4.37GB, when i try to extract it, it says it's too large, so i'm at a lost trying to extract it so i'm trying to figure out how to extract it, and u said to convert my hdd to ntfs, i'm at a lost with that too, never heard of neither like i said b4, sorry.
A partition in your hard disk can be formatted in NTFS format. NTFS format allows larger files and is better than FAT 32 in general. If you do not want to reformat your partiton with the operating system in it and if you do not already have additional partitons on your HD or you do not have two HDs, create an additional partition on your HD and format that to NTFS and put file here and extract it here.
See WINXP Help for sequence to create additional partition and reformat that partiton to NTFS.
I am not an expert but think this will work. -
XP comes with a standard utility to convert your FAT32 to NTFS on-the-fly. Try this in a command prompt windows ...
CONVERT C: /FS:NTFS
(you may need a /X option as well) -
A little light reading for you
http://www.microsoft.com/technet/prodtechnol/winxppro/maintain/convertfat.mspxRead my blog here.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Can't convert very big file
By Julio33 in forum MacReplies: 3Last Post: 16th Dec 2010, 15:18 -
Too Big Clip File
By kamyogi in forum Newbie / General discussionsReplies: 3Last Post: 12th Aug 2009, 07:51 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40 -
conversion file to big
By jimk16 in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2007, 05:05
