I am trying to play Ali on windows media player. I installed the divx codecs and have the latest windows media player since it comes with windows xp. It still doesnt work and comes up with a bad format error. Anyone been able to play divx on windows xp with mediaplayer or anyone know how to fix this ?????
WK
:P All the DIV-X Movies I've tried under Win XP with the Media player run just fine...... I'm using the Div-x 3.11 codec....
I've had a bit of trouble with XP but eventually got it worked out. Version 3.11 of DivX works great but the newer 4.12 has some problems, mainly with audio/video sync and not being able to play all files.
A couple things I'd suggest are to install the latest version 4 DivX codec pack and then install the older 3.11 version after. Although the ver 4 package supports 3.11 I find it has trouble opening the files. I'd also suggest trying to use MediaPlayer 6.4 which is included in XP. It's called mplayer2.exe and you can find it in the C:\Program Files\Windows Media Player folder.
Another thing is to run your file through a tiny program called divfix which is available for free on various divx sites. Or you can open the divx file in Virtualdub and do a direct stream copy of both audio and video to create a more stable version.
The last thing is to turn off video acceration in the Windows MediaPlayer if you get the "upside-down" playback of DivX files. Go to tools->options-> performance->advanced and uncheck the "use video mixing renderer" box. -
Well i think after trying all of above that my problem is that my divx is broken. First of all does anyone know what that means, next my pc did freeze while i was downloading ali and i had to resume it while i was around half way done. Would that make it a broken divx ???
atuln007,
First off, I'd be very skeptical with any files I download off the internet, especially screener divx files. From my experience, most divx screeners are very poor in quality, and no telling how they were encoded.
Secondly, from my experience, WMP sucks as a divx player. I'm not sure if this recommendation can help you with your current problem, but for future divx playback, I'd check out http://www.powerdivx.com/ and download their next generation divx player ( I think it's 3.12 or 3.11)
Regards
DVD Player capable of playing DivX Plus HD Content
By werty12345 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Nov 2011, 21:11 -
WinXP SP3 Problems Installing Media Player 11
By bevills1 in forum ComputerReplies: 0Last Post: 31st May 2011, 11:00 -
Help Playing divx from external HD through dvd player
By Medward in forum DVD & Blu-ray PlayersReplies: 5Last Post: 19th Sep 2007, 14:14 -
Ripped/burned AVI DivX files not playing in pc or DVD player
By perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 03:55 -
playing avi file with subtitle in standalone divx player
By weeleong87 in forum SubtitleReplies: 19Last Post: 16th May 2007, 18:32
