I have a movie i was given that is in an AVI format. I am going to use WinAvi to re-dub it into a smaller file to burn on a CD-R. I am curious though, it asks for mpeg1 or mpeg2. What is the differences? quality? size? etc... Should I use mpeg1 or mpeg2 for my re-dub???
I have a toshiba dvd player that will play mpeg's so I'm sure it will play either. just wondering.
T
No difference quality wise.
"Art is making something out of nothing and selling it." - Frank Zappa -
avis are usually squished about as much as possible without losing alot of quality. what are you going to play the smaller files with once you convert them?
1. you'll find no fans of Winavi here.
2. unless you have huffyuv or dv in that avi file the visual result of what you're trying to attempt is going to be shit
3. mpeg4->mpeg2 means going to a greater filesize. up to 3-4 times the original mpeg4 avi.
4. if your toshiba can play mpeg4 you can re-encode to something it likes and squeeze it to a single cd.
5. post more details details details
6.starting by using gspot to get info on your avi file. -
Backdraft(1991)EngDvDrip[Eng Subtitles].avi
size:708 MB (725,556 KB / 742,969,344 bytes)
audio codec:0x0055 MPEG-1 Layer 3
audio info:48000Hz 114 kb/s tot , Joint Stereo LAME3.89 (beta)
video codec
IVX
video name
ivX 4 (OpenDivX)
size:640 x 352
what else do you need?
i am rather new to this so if winavi is NOT a good program then what would u guys recommend to use to convert an avi to a mpeg file?
something rather easy to use for novices would be nice.
thanks for your help
T -
guess you are new here. you can't ask for help with pirated movies here. don't ever mention anything about them again or you could get banned.
Easy answer .... buy the dvd .... no questions will be answered about pirated movies
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
Converting from xvid avi to mpeg-2
By busbee2 in forum Video ConversionReplies: 5Last Post: 12th Dec 2009, 23:44 -
converting mpeg to avi
By extremebeat in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 13:07 -
Converting AVI file to mpeg 2 question.
By ingeborgdot in forum Video ConversionReplies: 17Last Post: 7th Nov 2008, 20:49 -
converting avi to mpeg-1 help plz??
By darealest1 in forum MacReplies: 5Last Post: 12th Jul 2007, 21:43
