I have a PAL DVD that I want to convert to NTSC for use in my dvd player. I used IfoEdit to patch the ifos as per this guide: https://forum.videohelp.com/viewtopic.php?t=221928
However, now when I try to access the menu on my computer (using MPC), I cannot make any selections. I can directly play the videos by opening the VTS_01_1.ifo file or subsequent ones. However, the menu contains the chapters for this DVD and it will be a real pain to go through and recreate those. Since the video itself is fine, is there some way I can transfer over the chapter points say into GFD or TDA so that I can create a new menu with the videos and keep the chapters intact?
Results 1 to 1 of 1
My still menu w/ music doesn't work right in some players
By Radish in forum Authoring (DVD)Replies: 9Last Post: 26th Mar 2009, 20:19 -
Vob file doesn't work, but it used too
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2008, 07:47 -
Any good multi-region DVD player that plays PAL/NTSC and upcoverts?
By jtrinc in forum DVD & Blu-ray PlayersReplies: 9Last Post: 13th Jun 2008, 19:12 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
using pal material to work in an ntsc format
By rapidondamove in forum MacReplies: 2Last Post: 7th Jun 2007, 17:22
