I am capturing from VHS to PCI capture card using conexant 2388x chip.
The tape I'm capturing from is from a time lapse recorder (i.e. security cam).
I can play the tape out to a TV without issue, however it moves a bit 'fast'.
When I play and capture through card, I can see and capture ok, however every few frames it acts like it would if there were a 'tracking' problem, i.e. a VCR from 1985 which this one is not. The image shifts on the screen so the very top is at the bottom. It seems like this would be a frame rate (or bit rate?) issue but messing with settings in capture software hasn't helped.
Just wondering if anyone has any experience in this arena.
Thanks.
Results 1 to 1 of 1
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
Capturing video from a European VHS tape through RCA out
By c627627 in forum Capturing and VCRReplies: 71Last Post: 23rd Mar 2010, 15:19 -
"No signal"-capturing from VHS-tape
By Mållgan in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2008, 04:21 -
Question about capturing VHS tape to .avi file
By rfdillon in forum Capturing and VCRReplies: 6Last Post: 27th Jul 2008, 01:44
