Hi,
Had some trouble playing a Divx file with WMP, the file just wouln't play, while Media Player
Classic(MPC) played it well. turned out, it always happens when DirectVobSub was loaded.
it looked strange to me, because i'm using this combination many-many times, so why now?
in short, my movie is 352X268 (WxH), and Resolution property in DirectVobSub was defined:
DirectVobSub > General > Resolution = "Double if smaller than 384X288".
i changed it to "Original resolution", and everything is OK now.
Question is, why the "Double.." definition is honored with MPC, but not with WMP?
the same DivX codec is used in both cases, so, if it is a simple matter of 1+1=2,
i'd say it's a bug in WMP, but i have a feeling that it's not that simple.
any ideas?
thanks
Results 1 to 1 of 1
Jacobmu
DirectVobsub and WMP 12
By mrcoolekin in forum Software PlayingReplies: 4Last Post: 27th Apr 2012, 02:49 -
MKV to MP4 - issue with DirectVobSub and ffdshow
By fzero333 in forum Video ConversionReplies: 0Last Post: 7th Jan 2012, 16:12 -
AviSynth - JDL_ApplyRange() & FadeIn() Compatibility Issue?
By Typhoon859 in forum Video ConversionReplies: 18Last Post: 4th May 2009, 19:29 -
Sound Card Compatibility with After Effects CS3 Issue...
By Angelus22 in forum EditingReplies: 1Last Post: 28th Oct 2007, 07:20 -
PAL + NTSC Compatibility Issue !?
By ells6363 in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2007, 12:37
