Hi!
Mencoder is working perfect for multiplexing video both with ac3 and wav but why will the resulting video only play back descently in mMplayer? The utility VlcMediaPlayer is playing only the sound without visuals and WombleMpgEditor only shows the video without audio. WindowsMediaPlayer shows nothing at all and complains for not finding the codec. My settings are:
mencoder -ovc copy -oac copy -audiofile C:\Sound.AC3 C:\Video.MPG -o C:\Output.mpg
Question: Which codec is needed for playing the video normally in VlcMediaPlayer etc.
Thanks in advance// Christer Holmberg
I would try multiplex with mplex and see if it works better.
Can windows media player play other mpeg2 files fine? -
Answer 1) Yes thankyou, mplex did a great job for me muxing video.mpg and audio.ac3. Sadly mplex ignores CBR160.mp3 and 44100.wav.
Answer 2) Yes, Windows Media Player is able to play other mpeg2-files fine including VOB-files.
I have great respect for mencoder but now it seems like I have to use a lot of other utilities.
My first question still remains unanswered.
Thanks Baldrick for helping this far// Christer -
Originally Posted by Christer
Check in GSpot.Code:WARNING: OUTPUT FILE FORMAT IS _AVI_.
Try...
orCode:mencoder -of lavf -lavfopts i_certify_that_my_video_stream_does_not_use_b_frames:format=mpg -ovc copy -oac copy -audiofile sound.ac3 video.mpg -o output.mpg
Code:mencoder -of lavf -lavfopts i_certify_that_my_video_stream_does_not_use_b_frames:format=mpeg2 -ovc copy -oac copy -audiofile audio.ac3 video.mpg -o output.vob
VLC not use external codecs - only internal.Question: Which codec is needed for playing the video normally in VlcMediaPlayer etc.
How do I rip Blu-Ray/DVDs to same quality muxed files 4 Hard Drive playback
By Zakko in forum Blu-ray RippingReplies: 13Last Post: 24th Apr 2011, 13:42 -
Can flac or .ass files be muxed into a MP4 container?
By Cyber Akuma in forum Newbie / General discussionsReplies: 5Last Post: 29th Oct 2010, 15:47 -
Probable Codec problem. No audio on MPEG2 muxed files
By Kevlin in forum MacReplies: 14Last Post: 17th Apr 2010, 04:05 -
How can i view muxed .sup files in .m2ts?
By b66pak in forum Software PlayingReplies: 0Last Post: 31st Dec 2008, 14:33 -
Converting to H264 [.MP4] (mencoder) results in video playing too fast
By ChrisMtl in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2008, 17:02
