Hi ..
How are you .. I hope fine![]()
I faced a problem with dvd lab pro ..
when I open it .. nothing happens .. I just wait and nothing get opened
- I checked the process in task manager , and dvd lab pro was sorted their -
Quote : I tried to use dvd lab and it worked .. but its unuseful .. the pro version is much better .
so I hope you can help me with that problem .. because I really need that program
Thanks alot![]()
and GoodBYE
Hi ..
thanks for the answer
actully I've already done all what you said
but .. no matter .. I'll try doing it again
thank you
and goodbye .. -
hi agin
I've done all what I'm supposed to do ..
but ,, unfortunately .. nothing happened
thanks ..
and Goodbye .. -
I strongly suggest you report the problem the MediaChance support, and also post the problem in the DVD Lab Pro forums here : http://www.mmbforums.com/phpbb/viewforum.php?f=24
The author hangs out there, and can answer you directly.Read my blog here.
thanks alot for your help ..
and I'll post my problem there
goodbye ..
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
