hi
i authored and then burned my video dvd but when it plays in dvd player - the picture is shaking like 10 times a second? however the disc plays fine on computer... what can be the cause?
My first guess would be wrong field order. That can be caused by the encoder settings or trimming in the wrong place and messing up the field order. I believe Gspot may be able to show the field order in in VOBs, but I'm not sure exactly what to look for there.
Or I might be completely wrong. I've only ran into that a few times, and I usually just re-encoded with the correct FO and everything was fine.
What was your source media format and what program did you encode with? -
Could be field order. Could just be really bad converting.
If you simply resize from PAL to NTSC resolution, then encode at 29.97 or 23.976 fps, you will not only potentially screw the interlacing, but you could also be dropping or creating frames in a manner that will make the image appear to stutter and jerk.
FulicLives' guide is probably the most definitive read on format conversion using tmpgenc, although any good encoder will do the job (and faster . . .). Have a read here : https://forum.videohelp.com/viewtopic.php?t=300144
Read the whole thread, as it refines the processes as it goes.Read my blog here.
How to remove shaking camera effect
By jairovital in forum RestorationReplies: 20Last Post: 17th Apr 2012, 14:29 -
DVD video appears distorted/shaking on sides when played on TV
By Blueknight in forum DVD RippingReplies: 0Last Post: 6th Feb 2011, 16:48 -
Strange shaking effect in recording while moving the videocamera
By anegroo in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2010, 09:25 -
Green shaking converting
By MOBBRO in forum Capturing and VCRReplies: 1Last Post: 24th Sep 2008, 07:17 -
movie is shaking
By shlomik101 in forum Authoring (DVD)Replies: 1Last Post: 28th May 2007, 05:01
