I use SUPER to convert my flv files to other formats. But I was wondering which format would be the best for DVD Authoring? Please mention the Audio & Video settings too.
Results 1 to 13 of 13
There is no patch for ignorance...
The best?
All DVD players play mpeg2
Some are starting to play other formats.
Need more info on exactly what you're trying to accomplish. -
The screen shot was very helpful. Unfortunately, there is a lot wrong with what you did. PLEASE look at the link on the top left for "What Is DVD" to understand what the format requires.
MP3 is dead wrong for DVD. You need either AC3 audio or PCM (don't recommend it as it takes up too much space). AC3 is best. A sampling frequency of 44100 is wrong too. DVD requires 48000. Your decision not to change the video resolution is probably wrong as most FLV clips I've seen don't have valid resolutions for DVD. Again, please look at the link to understand what you need as a final product. You did get the frames per second right if you want to make NTSC (used in North America) DVDs. -
I know the settings might be wrong for DVD. But why wont the mpg file play properly before I convert it to DVD??? I've attached what GSpot has to say about the mpg file.Originally Posted by jman98
newzealand_tv.flv.txtThere is no patch for ignorance... -
Atlast I found out why all my MPEG-II vdo files wouldn't play anymore!! I uninstalled some applications today, one of them removed the codec required to play MPEG-II files. Bullocks!!
I found out after carefully examining all those vdo's with GSpot(hats off to GSpot). So, where can I get the codec? Oh n thanks 45tripp for giving me just wat I asked. 8)
PowerDVD has no reliance on external mpeg codecs. If it's shot you need to re-install.
VLC is self-contained and doesn't need external codecs either.
If you want mpeg support for other players you could go with the popular ffdshow package.
Or if you just want to fix mpeg support try dscaler mpeg filters -
45tripp answered that one 4 posts ago. The settings are correct for PAL but you'll need to change the frame rate to 29.97 and the resolution to 720x480 for NTSC.
.....and you shouldn't need to stumble on the correct settings, read 'What is DVD' at the top left and you'll see what the correct settings are.
Blu Ray ripping container & codec question.
By jamesj84 in forum Blu-ray RippingReplies: 10Last Post: 15th Dec 2011, 12:18 -
What tool/s can I use to Mux/Edit H264 in FLV container? Avidemux only does
By tigerb in forum Newbie / General discussionsReplies: 9Last Post: 8th Dec 2011, 22:03 -
Mkv & FLV Conversion Trouble
By Simmons in forum Video ConversionReplies: 1Last Post: 9th May 2011, 12:55 -
Recording with high quality and good conversion methods (snagit & codec q.)
By mukunku in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2010, 23:43 -
best codec or container?
By crazydrve in forum Video ConversionReplies: 5Last Post: 30th Nov 2009, 06:20
Just read my first post again. As I already mentioned I use
