Could someone please suggest a program that I could use to make a menu for a dvd that has only avi's on it.
I don't want to convert the avi's, I want to leave them as is, just need a program so that I can play the dvd in my stand alone dvd player and be able to choose which avi I want to play
I have tried Nero & Pegasys dvd author but they both convert the avi's
Many thanks in advance for any suggestions
Not possible, except w/ a) the Divx codec and b) a Divx Ultra (I think it's called) capable player. If you want menus you're just better off converting; otherwise with a standard divx/xvid player sans menus.
Nero is rubbish and should be avoided, and will try to convert them to DVD format anyway.
The latest TDA will author Divx discs with menues etc, but will convert them to .Divx (which may be a simple demux/mux type exercise, or it may not) and the menus etc will only be usable on a PC using the Divx Player, or on Divx Ultra Certified playback equipment.Read my blog here.
What's the best software to make menu for an audio-dvd ?
By Theyodaddy in forum Authoring (DVD)Replies: 7Last Post: 18th Mar 2012, 19:58 -
DVD with chapters already I only want to make a menu while retaining all...
By dbbarney in forum Authoring (DVD)Replies: 6Last Post: 4th Oct 2010, 13:05 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 15:29 -
How do I make a menu for a video_ts folder that has no menu?
By ericg42 in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2009, 07:02 -
how to make a dvd from 2 or more different dvds with menu and subs??
By vinayak1986 in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2007, 02:59
