Does anyone know how to convert a Screendragon .flm movie file to something workable? For some reason I can't get any of them to play and I have an old CD-ROM from 7 years ago with some files on it.
flm is Photoshop Film Strip format..
you can play this in Drastic Preview http://www.drasticpreview.com/download.html
you can download a free beta version at the above link --
Drastic Preview plays many odd or professional type formats
Supported File Formats:
AUDIO: Windows Wave, Broadcast Wave (bwf), Apple/SGI Aiff Audio, Sun/Next Audio, Apple HCOM Audio , SF Audio, Sample Vision Audio, NeXT Sound, Creative Labs Voc, CD Audio, Unix Audio, MP3 Mpeg 3
VIDEO: QuickTime Movies, DV Movies, AVI, Avid OMFI, Avid MXF (XDCAM), Edit Decision List, DVS Direct File Format, Boxx Video Files, VideoPump Direct File Format, Newtek Video Toaster, PhotoShop FilmStrip, Windows Media, MPEG 1 4:2:0, MPEG 2 Elementary 4:2:0/4:2:2 SD to HD, MPEG 2 Program Stream 4:2:0/4:2:2 SD to HD, MPEG 2 Transport Stream 4:2:0/4:2:2 SD to HD, Jaleo Direct Format, SGI Movie Format, Profile GXF Format/SMPTE-360, MXF Format (DV, DVCPro50, DNxHD, Uncompressed), Avid DS HD/SD, HiCon32 SLB32 RFB, DPS Velocity Files, Iridas Frame Cycler, Separate YCbCr Streams, Separate RGB Streams, Sony MXF, Quantel MXF, Header/Raw Frame Stream, Aja ntv, DPS Velocity
STILLS SEQUENCE: (with optional side bar audio) DPIX, Cineon, Microsoft-OS/2 BMP, Microsoft DIB, Windows RLE, Targa TGA, Targa ICB, JPEG, Photoshop PSD, RAS, SGI, TIFF, TIF, AVS, Portable Bitmap Format PBM, Photo CD PCD, ZSoft PC Paintbrush PCX, Portable graymap PGM, Portable anymap PNM, Portable pixmap PPM, Raw RGB Format, Sun Raster File SUN, Targa VDA, Targa VST, X Windows b&w XBM, X Windows color XPM, Accom YUV/YUV16 CCIR 601 8 Bit, YUV/iYUV 4:2:0, YUV 4:2:2 16 bit per component, v210 YCbCr 10 Bit, YCrCb 16 Bit, yuv2/uyvy 8 bit, Quantel VPB, MTV Raytracing image format MTV, .Y/.U/.V component, .BLU/.GRN/.RED, .luma/.rmy/.bmy
FRAME RATES: VariCam(1~60), 14.98, 15, 23.98/23.97, 24, 25, 29.97, 30, 50, 59.94, 60 or greater
FRAME SIZES: Variable(60~2048/1556), 720/704x480/486/508/512, 720x576/596/608, 1280x720, 1920x1080/1035, 2048x1080/1112/1536/1556
AUDIO: 8000Hz..96000Hz, 8/16/20/24/32 Bits, 2..8 Channels (2 Out, 8 Out in Pro)
to convert FLM files - just open it in photoshop (or perhaps also paintshop pro and others) and save it as something else"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Ripbot conversion of a 40 GB movie
By mario595 in forum Video ConversionReplies: 7Last Post: 11th Nov 2010, 22:35 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 12:41 -
4 min movie conversion
By Tahir Ramzan in forum Video ConversionReplies: 2Last Post: 3rd Jan 2009, 01:46 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 22:22 -
Converting a Shockwave file (non-movie) to FLV movie
By beyondthegrave in forum Video ConversionReplies: 3Last Post: 22nd Nov 2007, 01:18
