I have a dvd movie with a very crappy and stupid translation. So I want to edit the subtitle and put them back on the dvd.
I followed some guide here, demuxing with rejig, and i got a .sup file.
The problem is, there is no program out there is supporting .sup file for editing. Subtitle Workshop is no good either. Try changing it to .sub (still using rejig) and the subtitle workshop said that its a bad, corrupted sub.
There is a lot of program that saves to .sup but none supporting .sup for editing.
How can I edit this subtitle?
Its a 2 dvd and i want to compress it so it fit in 1 dvd, so using DVDsubedit is not a good idea, I think.
Do you know why people mostly use Mac in their office?
Because a lot of stress can lead people to jump off the "Windows". -
did you try DVDSubEdit ?
I'm using DVDlab pro so I dont need to convert it to sup. DVDlab cant read sup files other than their own sup.
DVDsubedit can read those sup, but they cant edit it, only delete it. Thank god there is an option to save it to srt. I think i'll use that.Do you know why people mostly use Mac in their office?
Sup files are just compressed (by RLE) pictures. The only way to edit those, would be a image processing program (Paint, Gimp, Photoshop...). To edit this as text, you have to OCR the text on the pictures and edit the resulting text file. Then you can use a subtitle render engine (SubtitleCreator, txt2sup...) to convert the text back to sup, or use an authoring program with a built in subtitle render engine like dvdlab.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Editing After Effects Subtitle Script
By evil nemesis in forum EditingReplies: 0Last Post: 20th Feb 2012, 11:03 -
Editing subtitle on diferent positions
By Capum in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2010, 09:59 -
Editing a DVD subtitle timing?
By yonyz in forum SubtitleReplies: 0Last Post: 5th Mar 2009, 02:35 -
editing with subtitle workshop
By aruwin in forum SubtitleReplies: 1Last Post: 26th Jun 2008, 13:24 -
Subtitle editing & synchronization.
By plomon in forum SubtitleReplies: 15Last Post: 13th Apr 2008, 00:16
