i have now a 2 movie each movie has 700mb file size and it is hardsub using AUtoGK.
now i wan to burn these 2 movie's in a single DVD..
how? [ 2 in 1 ]
Results 1 to 10 of 10
try and try
I am assuming you want them in MPEG-2 DVD format? Simple would be to use a program like ConvertXToDVD, add them both and let it make a DVD for you.
Or you can encode them with other converters and author them both to one DVD. -
ah ok.. tnx..
winavi convert avi to mpeg-2 also.. can i use that ?
and after that, i could burn it to nero vision?try and try -
Personally, I wouldn't use either of those programs, but if you can get them to work properly, you probably could use them for that process.
For just burning DVDs, the freeware ImgBurn is one of the best programs out there. It accepts VIDEO_TS folders and works well with the newer burners.
You could also try the older version of ConvertX, the freeware DivxToDVD. It's not as flexible, but I suspect it will work better than WinAVI.
NeroVision sometimes works, sometimes doesn't. Both it and WinAVI do not have a good success record, IMO.
i converted my xVid avi movie [700mb] with WinAvi to mpeg-2 and the result was ok but the file size was about 1.8 Gb. is that really the file size? or it should be less than that?
regarding to suggestion [ImgBurn,DivxToDVD] ok il try to use them and get some results.try and try -
Yes, that sounds about right. You'll be able to fit 2 movies on a single disc if the other movie comes out to a similar size.Originally Posted by ianskieeEven a broken clock is right twice a day.
Actually, that seems small if you want any sort of quality.
What is the running time of each movie ?
Size = Running Time X Bitrate. The longer the film, the lower the bitrate, and consequently, the lower the quality after a certain point.
Given your source is low quality to begin with, 1.8GB might be OK if you had used a decent encoder. However 1.8GB out of WinAVI will be very average at best.Read my blog here.
the running time was about 1 hour 55 mins and 22 seconds.Originally Posted by guns1inger
8)
*guys, you know what, when i used convertxtodvd, after the conversion and it was burning to disc, suddenly an error occured saying that Burn disc error.try and try -
I never burn with ConvertXtoDVD. I write the disc to the HDD, then use Imgburn to burn to disc.
Read my blog here.
guns1inger is right...
I "assumed" (gasp!) you encoded at 1/2 D1 (352x480) which would make your file size about right. However, if you had it encode at 720x480 then a 1.8gig file would look pretty bad.
What can I say? My bad!Even a broken clock is right twice a day.
Burn more than 1 movie on same DVD
By smithwigglesworth0 in forum Authoring (DVD)Replies: 20Last Post: 31st Aug 2011, 23:34 -
Burn Movie to DVD
By pfisher in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2011, 19:40 -
Burn movie from C Drive to DVD
By rwhite4photos in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2011, 17:36 -
Help getting a movie ready for DVD burn
By therock09wbt in forum Video ConversionReplies: 7Last Post: 3rd Jan 2011, 20:03 -
How to burn 7.1 channel DVD movie?
By coody in forum AudioReplies: 7Last Post: 9th Dec 2009, 05:07
