Hi,
Provided are 2 clips from the same documentary-film. Each clip is 20 sec. long (30MB a piece)
You could say they are "fair broadcast quality"
http://rapidshare.com/files/25837806/vobclip1.vob
http://rapidshare.com/files/25837807/vobclip2.vob
Could you guys make suggestions what to do to enhance this footage?
What I'd like to see fixed:
*Theres this white overall haze over the whole image of the video,
and its not sharp. Both clips demonstrate that, especially clip 1
*Then Saturaton fluctuates between very bright and kind of darkish.
As if used a very old camera.
This is the same MPEG-like quality you can expect from LaserDisc (?) I suspect.
(I done some laserdisc-2-PC captures before, all of the same type of quality)
Really would like your oppinion on what to use to improve this. I use Avisynth myself.
Thanks again.
Results 1 to 1 of 1
*OLD* CD Restoration
By kallisti5 in forum RestorationReplies: 13Last Post: 6th May 2011, 07:11 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 17:03 -
Seeking VHS Restoration Filter Suggestions on Sample
By Yaemish in forum RestorationReplies: 1Last Post: 23rd Dec 2008, 22:13 -
VHS restoration
By degacci in forum RestorationReplies: 5Last Post: 5th May 2008, 02:02 -
Restoration
By KMJvet in forum MacReplies: 15Last Post: 15th Apr 2008, 17:08
