i was encoding a movie and my comp crashed and stopped at 48%.....how can I, if possible, begin econding from the point again using TMPGEnc?
~Dan
It depends. When your computer crashed did you still get the first part that you were encoding? Basically, when you restarted the computer did you get the 48% encoded or did you lose it when the computer died? If you got that part just look at the time, load the full original, go to advanced tab, go to source range, set the first frame to where you left off, and the last frame at the end.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
How old are you - part 2 (no lying now)
By yoda313 in forum PollsReplies: 95Last Post: 4th Oct 2009, 10:00 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36
