    Jan 2006
    Lately I've noticed print problems for web email and some adobe acrobat forms such as income tax forms. From just left of center the printed page fades out until the page is completely blank for the last 30% of left side of page. A FedEx label recently printed just fine as well as some rebate forms printing fine as well, but all web email and some acrobat forms fade out left of center of printed page. This is a Samsung ML 2010 laser printer connect via USB 2.0 to Windows 2000 system, and latest 8.0 version of Adobe Acrobat Reader is installed; also tried older 6.0 Acrobat version with same results. Has anybody had this kind of problem or know how to possibly fix it?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Have you tried just printing a test page or two? Most print issues of this type are hardware, not software related.
    Google is your Friend
    Jan 2006
    Solution came from same query posted on another site which was to shake the cartridge. I wouldn't have thought this to be the solution since some pages printed perfectly, but it did resolve the problem.
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Ahhh, low toner.
