I use Adobe Premiere Pro and I'm looking for a solution to create a custom on screen video counter - using minutes and seconds in this format 1:00 . I'd like to the actual time running as my video clip is playing. Is there a plug-in I can get to create this? If anyone knows of anything I can use, please share it.
Thanks!
I'm going to be exporting my timeline to an AVI file and then converting it to a flash FLV file for the final product. Will this still work?
If you are creating a Flash file, why not use ActionScript to generate the counter?Originally Posted by foochuck
Have a look at http://www.enosoft.net/products/enodvdec/enodvdec.htm
There is a Flash object with a counter etc. In this case, there is just a single still image but you can do the same thing with a movie. (The ActionScript also uses your computer's clock to display the time and date).
The ActionScript is:
Code:function updateTimecode() { timecode.text = ""; var milliseconds = getTimer(); var seconds = int(milliseconds / 1000); milliseconds = milliseconds - seconds * 1000; var minutes = int(seconds / 60); seconds = seconds - minutes * 60; var hours = int(minutes / 60); minutes = minutes - hours * 60; var frames = int(milliseconds / 33); if (hours < 10){ timecode.text = timecode.text + "0"; } timecode.text = timecode.text + String(hours) + ":"; if (minutes < 10){ timecode.text = timecode.text + "0"; } timecode.text = timecode.text + String(minutes) + ":"; if (seconds < 10){ timecode.text = timecode.text + "0"; } timecode.text = timecode.text + String(seconds) + ";"; if (frames < 10){ timecode.text = timecode.text + "0"; } timecode.text = timecode.text + String(frames); updateAfterEvent(); } function updateRectime() { rectime.text = ""; recdate.text = ""; now = new Date(); var seconds = now.getSeconds(); var minutes = now.getMinutes(); var hours = now.getHours(); var day = now.getDate(); var month = now.getMonth() + 1; var year = now.getYear(); if (hours < 10){ rectime.text = rectime.text + "0"; } rectime.text = rectime.text + String(hours) + ":"; if (minutes < 10){ rectime.text = rectime.text + "0"; } rectime.text = rectime.text + String(minutes) + ":"; if (seconds < 10){ rectime.text = rectime.text + "0"; } rectime.text = rectime.text + String(seconds); if (year < 110){ recdate.text = recdate.text + "0"; } recdate.text = recdate.text + String(year - 100) + "/"; if (month < 10){ recdate.text = recdate.text + "0"; } recdate.text = recdate.text + String(month) + "/"; if (day < 10){ recdate.text = recdate.text + "0"; } recdate.text = recdate.text + String(day); updateAfterEvent(); } setInterval( updateTimecode, 33 ); setInterval( updateRectime, 1000 ); _root.createTextField(timecode, 1, 50, 50); _root.createTextField(rectime, 1, 50, 50); _root.createTextField(recdate, 1, 50, 50); updateTimecode(); updateRectime(); -
Good idea. I'm gonna test out this code. Thanks
You'll probably need to change the event timing. I suspect ActionScript may be able to trigger events when a movie changes frame - but I'm not sure since I haven't tried it with a movie.Originally Posted by foochuck
Adding Timestamp or counter
By hdbrandon in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2011, 18:06 -
Blank screen when playing video on 'full screen'
By RAYPEV in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2011, 20:40 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Remove Counter
By Mark-Leon in forum MacReplies: 13Last Post: 29th Dec 2008, 12:12 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
