    Apr 2007
    Why is the Blu-ray player so big and can it play DVD's?
  2. so you don't feel so bad for paying the R&D costs when you buy the unit. you know...big being better (ha-ha).
    Apr 2007
    In the future there will be a compact one!
    This is just a beta version! :P
    Yes, just found out it was compatible with DVD's.
    It wasn't really designed for it but then again it wasn't also designed for CRT televisions!
    It was just an option!
