I have a lap top. It seems when I plug my external hard drive into the USB, the other USB seems to slow down, which is my wireless mouse.
Is there any way to fix this problem?
And also why does it exactly slow down my mouse speed?
Results 1 to 14 of 14
USB is limited on bandwidth. But the computer also has to address the USB devices for housekeeping and monitoring, so there is a lot of OS traffic going through the USB bus back and forth to the devices. With a high bandwidth external device like a hard drive, I would remove other USB devices or you may have problems. You may be lucky it just slows down your mouse and you haven't been getting dropouts.
If it's important for you to use a mouse when you have your USB hard disc attached, you can use a PS/2 mouse instead if your laptop has a PS/2 port.
I had the same problem with a USB wireless internet device eating up all of my speed. There is definately a limit to what even 2.0 can handle.
Originally Posted by Sudden Impact
You face the problem because USB (by design) cannot reserve bandwidth for a given device. On the other hand firewire allows this. -
...or you could get a cardbus USB card.
Nothing can stop me now, 'cause I don't care anymore. -
I don't even know if my E-Book hard drive has a firewall...aren't those hard drives more costly because it allows fire wire?
I'm looking at my lap top, i dont even see a firewall connection outlet...but then again, im a retard.
Get a pcmcia usb or firewire cardHunting, sure i'll go hunting. When is cow season? -
I use a combo USB 2.0/FireWire PCMCIA card with my laptop. The laptop just has USB 1.1 on board. And if you are shopping for a hard drive enclosure, getting one that has both USB 2.0 and FireWire will give you more options for just a few dollars more. With a HD enclosure, you can use most any available and compatible hard drive.
A couple of combo PCMCIA cards are on this NewEgg page: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=pcmcia+firewire
For enclosures take a look here: http://www.usb-ware.com/drives.htm -
make sure you are using a 'powered hub' do not plug devices that need power like an external usb pocket drive , into a NON-powered hub along side the mouse, the power requirements and voltage drop will affect the mouse
Question on USB Memory Sticks..
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 15th Feb 2012, 09:57 -
Question about USB to Firewire?
By Lucid_Dream in forum ComputerReplies: 1Last Post: 4th Jan 2011, 11:37 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 10:24 -
question about sony bravia usb connection
By ivyer in forum DVB / IPTVReplies: 3Last Post: 1st Nov 2009, 04:53 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 15:50
