Hello there, i'm currently running Windows XP Professional, w/ Service pack 2 on a P4, 3.06ghz machine with 2GB of ram & an Asus MB, i have an Aopen DVD Burner with dual layer capability & it won't allow me to burn dual layer discs. I thought there was a problem with my drive so i purchased a brand new LiteOn DVD Burner with dual layer capability & it does not burn dual layer discs on my computer either.
I loaded up Nero Info Tool to view what the drive is capable of & neither drive shows that it's dual layer compatible even though i KNOW it is.
I have the most updated firmware installed on both drives, i have up to date aspi files & I'm using the same programs/versions my buddy is using. (he installed them on his machine to test them out & they work fine).
I'm using DVD Shrink & Easy DVD Shrink & Nero & they all burn DVD5 discs fine but not DVD9. Both these drives ARE dual layer burners for sure & of COURSE i'm using DVD9 discs....but it doesn't matter what type of disc I use @ the moment because my computer thinks these burners are NOT dual layer compatible when they ARE!!!!
I'm wondering if i'm missing something or what could be causing these drives not to show as dual layer capable in EVERY program i've tried.
The only thing i can think of is that it could be a windows/software issue. The only thing i can think of doing is a format of my machine & a full re-install but that's HOURS of work i really don't wanna have to do, especially if that's not the problem. Any ideas?
Feel free to reply here for others who might be in the same boat as i, but i'd really appreciate a direct email with some suggestions/the solution! I can be contacted [LINK REMOVED]
Thank you in advance for your help!
You are in breach of the forum rules and are being issued with a formal warning. Double post using 2 user names and two different IP's in an attempt to hide. BANNED
/ Moderator offline
Closed Thread
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Is My Current Computer Capable?
By Sckinhunter in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2011, 09:51 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Is this remote capable?
By random0xff in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Feb 2008, 10:23 -
AVI capable player not showing all files on data disk
By Seeker47 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 22:07
