I am looking at some of my parents digital 8 stuff from sony..video is perfect, but there is a fair bit of motor noise....is there a way in vegas to get rid of this noise?
or any other program or VST plugin?
thanks
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
motor noise from the video-drum and mechanics can be very inconsistant.
Thats why removing it whole will be tricky.
Then again you CAN get good results with (what I know how to use) cooledit or now "Adobe Audition."
The standard functions in AA are sufficient for this task. If you know how to remove pink noise
etc. from songs, then this works the same way.
I know motor sound has a 'ticking sound' wich is not really constant, still you can get good results.
Finding out what the best settings are per/tape do need experimenting tho..
good luck! -
Goldwave, SoundForge, Audition
But there is not a magic "remove motor noise" button. It'll take quite a bit of effort, experience and skill. And you may never be able to fully remove it. Just be aware of that.Want my help? Ask here! (not via PM!)
Try www.wrigleyvideo.com. They have a great tutorial under Audition.
The usual is way is to record a sample of the noise (noise pattern), then filter it out. Most audio editors can do that, but I was never satisfied with the result - strange artificial sounds appeared and the stream became very muffled.Originally Posted by ron spencer
Have a look at Sound Forge 8.0's Audio Restoration tool (7.0 or older versions don't have it). I found it suprisingly effective reducing noise without screwing up the audio. The best I've seen so far. Hope this helps. -
Adobe Audition is great for this job, hints for noise reduction you'll find at my audio page. Magix has a good cleanig product as well, easy to use but it doesn't tell you much about its internal procedures.
Cheers -
Note: with most of these products, it's better to do a couple of passes of less processing each rather than 1 pass of lots of processing (kind of like planing a piece of wood or peeling an onion). Plus, use a couple of different kinds of tools-this sound isn't monolithic, so one tool won't completely cover it (unless you had a "ANTI-CAMERANOISE" filter).
Determining audio cassette noise reduction encoding type?
By jbd5010 in forum AudioReplies: 5Last Post: 28th Feb 2012, 21:18 -
Speaking of noise reduction, what is this?
By takearushfan in forum RestorationReplies: 11Last Post: 5th May 2010, 21:14 -
VHS Audio Noise Reduction / Rumble
By Vidd in forum AudioReplies: 4Last Post: 1st Mar 2009, 15:47 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 06:23 -
Video Noise Reduction ----> H E L P
By wxyz in forum DVD RippingReplies: 14Last Post: 21st Jun 2007, 19:22
