Hi,
I'm a newbie and I'm trying to find a software program that will allow me to cut part of a video out. All the video files I have are avi files. I have films that are over an hour long but I only want 5 minutes of some of the films. Could someone recommend a program that would do this in the easiest and user friendly way possible?
Results 1 to 9 of 9
VirtualDubMod. See the many tutorials.
http://www.kiva.org/about -
Ok, I got virtualdub...but ti's a zip file. Do I just unzip all the files into a folder? Also, do I need to do anything with the auxsetup.exe file?
Originally Posted by edDV
yeah, the problem is all those tutorials have nothing to do with editing a divx, they're all about converting stuff from one thing to the next.i am not you am not i am not you am not i am not you am not i am not you am not i am not you. -
pondleaping: https://www.videohelp.com/guides.php?guideid=357#357 , basicly the same for virtualdubmod.
Just set audio and video to direct stream, save as AVI once you're finished. DivX or XviD or DV or whatever doesn't matter.
/Mats -
Use the newest versions of Virtualdub ( 1.7 ) with Smart Render to exact frame edit.
Make sure you set the compression under video to match the compression of the original avi. If it's XviD, set the codec to single pass target quantizer.
You can either use Fast Recompress or Full Processing Mode with Smart Render. It Direct Stream Copies most of the file and only re-encodes where there weren't any key frames at your cuts.
Using Direct Stream Copy in VirtualdubMod or older versions of Virtualdub will not let you exact frame edit. -
yeah thanks folks, i think i may have mastered the virtualdub, still it's gonna be very time consuming editing 10 second clips but ill give it a try. pity i cant use WMM
Cutting out portions of video
By Jacks_Daddy07 in forum EditingReplies: 4Last Post: 18th Aug 2011, 16:18 -
Need help cutting out video segments and making one video with them
By darkcyber in forum DVD RippingReplies: 2Last Post: 23rd May 2011, 17:26 -
cutting Video Without Re-encoding
By stallion2008 in forum EditingReplies: 2Last Post: 30th Mar 2011, 17:03 -
video cutting
By Mr anderson in forum EditingReplies: 2Last Post: 21st Oct 2010, 14:42 -
the right format for video cutting
By Aivc in forum EditingReplies: 7Last Post: 10th Apr 2010, 09:57
