Hi, I'm appealing to the experts here for some help - I have a trial copy of Flash 8 Pro and have managed to learn a bit about customizing an FLV player w/an xml-driven playlist tonight, but the result is still FAR from perfect:
http://seimone.com/video/sd_videotest.html
As you can see, I've managed to piece together the playlist, but where my knowledge breaks down is in targeting the playback device where the FLV is supposed to load. The above example, which is the result of trial and error (mostly error) and several hours of reading through tutorials on Adobe Devnet and other sites, uses 4 FLV files, one of which I encoded myself (the first one). The others are from a tutorial.
Two major problems:
1) How do I generate a player, skinned like the one in the example (which is really just a background image) that will load each clip as it's selected? The original tutorial had each clip loading into a blank part of the stage, without a 'player,' so that's why I'm not sure how to do this.
2) The clip I did myself, WNBA Draft, appears abnormally large. I don't remember selecting any large settings when I encoded it from WMV to FLV, but unless it's constrained within a smaller SWF, it shows up much larger than intended.
The tutorial I originally consulted is here: http://www.adobe.com/devnet/flash/articles/prog_download.html
Any advice is greatly appreciated... I'm sure it's a simple fix, especially #1, but I don't know where to go from here.
thank you
Reading AVCHD Playlist files BDMV\Playlist\*.mpl
By StrangeSolutions in forum Newbie / General discussionsReplies: 11Last Post: 11th Jun 2014, 00:23 -
Simple VHS Capture Questions
By mostly_useless in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2011, 17:00 -
Some Simple AviDemux Questions - iPhone video
By hech54 in forum Video ConversionReplies: 9Last Post: 27th Oct 2011, 10:45 -
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47 -
Some simple questions about Dreambox and HTPC
By Talayero in forum DVB / IPTVReplies: 0Last Post: 8th Apr 2009, 12:44
