Results 1 to 9 of 9
    Mar 2007
    I have a ton of vhs and dvds that im going to be backing up onto blank dvds. I think I would need about a 100, but they are too pricey at stores like bestbuy and stuff.
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    The last 100 I got off of Ebay....I'll see if I can find the seller...
    http://cgi.ebay.com/100-SINGLE-DVD-Cases-W-push-hub-outer-sleeve-and-clips_W0QQitemZ19...QQcmdZViewItem
  3. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    I shop at effectuality.com, good quality cases
    What We Do In Life, Echoes In Eternity....
  4. Member classfour's Avatar
    The Heartland, United States
    www.supermediastore.com www.rima.com when they have free shipping
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    The dumpster at your local Blockbuster.
    44E
    Jul 2004
    I like that idea...
    The Devil`s always.....in the Details!
  7. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    Hollywood Video gives them away free, no need to go to the Dumpster.....
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
    The Blockbuster ones tend to be better than cheap stuff off eBay and whatnot. Why? Because the movie industry uses good cases, whereas most of the cheapy stuff from eBay and online media stores is recycled plastic products that are relatively flimsy. You'd want to deal with an online case supplier if you want good cases (Effectuality is one).
  9. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    Space is an issue for me, so I use slim jewel cases for many of my disks. I buy them at Officemax when they have buy one get one free on the 100 packs. Comes out $25 for 200.
    I also use CD prosleeves from case logic. I've found these double sided plastic sleeves for as little as 4 cents apiece. I store the sleeve in storage boxes. You can probably fit up to 400 sleeves in a sigle box which costs about $7 at officemax or staples.
