Do projectors shoot with progressive scan or interlaced? I'm going to be showing one of my videos at school and I was told it was going to be shown on a projector. If it was progressive and my video was interlaced, would I have to change my video's field order to progressive to get the same smooth movement in my video?
We would need the projector model number to get specific but most projectors will take either interlace or progressive source and convert internally to its native scan format.Originally Posted by seven_deuce offsuit
Any composite or S-Video input is by definition interlace. A VGA input is by definition progressive. If you are feeding 480i from the computer to VGA, your graphics card chips are making the interlace to progressive conversion.
Bottom line: You don't need to change your video. -
I was reading an article on progressive scan on wikipedia and it said this:
I don't know if that would matter for my video if you said was true. Since my video is interlaced I thought it would lose smoothness at a projector shooting at progressive scan. I remember showing a slideshow once on a projector and the movements and transitions weren't smooth. It was also an interlace video so I'm assuming the projector was progressive.Progressive scan will have half the frame rate of an interlaced scan's field rate, at a given line rate. This reduces motion smoothness, which may be a disadvantage in fast-changing images such as sports coverage. To maintain the same smoothness, double the line rate is required. -
This depends on the projector and the same issues would apply to a progressive television.Originally Posted by seven_deuce offsuit
If the projector is native interlace (e.g. DLP) then progressive is converted to interlace. If the projector is progressive, interlace to progressive conversion can be done crudely (e.g. 29.97i to 29.97p blend deinterlace) or done in various advanced "line doubling" modes (e.g. 29.97i to 59.94p adaptive, motion compensated, motion predictive, etc. deinterlace).
In other words, it can be done in a way that preserves motion resolution. It all depends on the technology in the projector.
nano projectors?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 1Last Post: 6th May 2010, 09:07 -
looking for some clarification on current projectors
By Seeker47 in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2009, 11:48 -
Home Theater Projectors
By Lucifers_Ghost in forum Off topicReplies: 17Last Post: 18th Sep 2008, 02:36 -
digital projectors??
By wan2no in forum ComputerReplies: 2Last Post: 16th Mar 2008, 20:34 -
Who Likes Projectors?
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 10th Jan 2008, 18:35
