Hi
How to author cellphone videos in a low resolution (176x144) to appear in dvd mode with their real size and keeping their quality. Everytime when i've authored them in dvd mode, they became largest and is almost impossible to identify the video( too much pixels).sincerely. sid![]()
How can I make a bicycle look like a Mercedes? Answer - you can't - if you try, you end up with a strange looking bicycle.
I asked the same question:
https://forum.videohelp.com/viewtopic.php?t=325363&highlight=
I wanted a black background with the cell phone video in the middle.
Still have not been able to do it.
Good luck.When it sounds too good to be true, it usually is!! -
No, you wanted an animated background...Originally Posted by Bronx
You can use tmpgenc plus and use the settings->advanced options to add black borders(set to custom size and set it to the size of the avi). And you can also use a low resolution like 352x240/288(it is dvd compatible). Use the file->preview to check how it looks like. -
Sorry I should read my own thread better.No, you wanted an animated background...When it sounds too good to be true, it usually is!!
Virtualdub's resize filter can add borders without resizing the original. You can then frameserve to an mpeg encoder to get a DVD compliant file for authoring.
Read my blog here.
Hi!
I've follow the solutions given and it functions perfect with virtualdub's. With tmpgenc plus i was not able to find the directions given. so i cant say if its ok or not. thanks too much.
Do you put your cellphone on vibrate or do you use a ringtone?
By yoda313 in forum PollsReplies: 32Last Post: 7th Jan 2024, 22:01 -
CellPhone Thread
By TechNight in forum Off topicReplies: 27Last Post: 10th Dec 2008, 20:29 -
Do you have video recording capability on your cellphone?
By yoda313 in forum PollsReplies: 32Last Post: 3rd Nov 2008, 06:37 -
help on converting cellphone recorded video to avi
By wingnut2003 in forum Video ConversionReplies: 8Last Post: 11th Jul 2008, 03:42 -
emailing photo from cellphone
By AlecWest in forum Off topicReplies: 3Last Post: 9th Nov 2007, 14:36
