Is there a way I can add picture slide shows between tracks of a music DVD?
Results 1 to 9 of 9
what authoring tool are you using today? do you want to add slide shows to an existing music dvd ?
at the moment, I'm just using DVD shrink to rip the DVD.
Basically, what I would like to do is have a 1 or 2 minute slide show between each music clip, sort of like a commercial of our business.
I'm open to any authoring tool that you recommend. -
Create the clips in any video software, encode to compliant mpeg2 video (see What is DVD, top left corner, for compliance).
From there you have a choice. Either author a totally new disc from scratch using your new video(s) and bits from the others, or author just your new video(s) to your HDD, then use DVD Shrink in re-author mode to put them where you want them.Read my blog here.
Windows Movie Maker, then save as DV-avi is probably the quickest way.
Read my blog here.
If you want a good free tool, here's Slide Show Movie Maker:
http://www.joern-thiemann.de/tools/SSMM/index.html
Selectable transitions, music themes etc. Saves as avi with a selected codec on your system, then you can encode it to MPEG2 and author the usual way. -
hi,
came across this :
http://www.easymadememories.com/
not sure if it'll meet your needs...
i'm also trying to do something similar i.e. creating a scrapbook with slideshows, jpgs and dvd... personally haven't try it yet... still wondering how to go about doing it...
Another way:
Once you have your various slideshow clips authored for DVD (I'd use AviSynth's ImageSource command to help turn them into DVD), open the original music DVD in PGCEdit, highlight each music video in turn (assuming they each have their own PGC/Title as is usually the case with music video DVDs), go Title->Import Title's Intro (or Closing) Clip, and follow the easy instructions from there. That'll save taking apart the original DVD and reauthoring the entire thing, and allow you to keep any original menus.
How can I cut/edit/merge/add some info/add hardsubtitle in one media (DVD)?
By roUndy_sh in forum EditingReplies: 8Last Post: 26th Dec 2010, 17:45 -
High definition slide shows on DVD.
By EagleW in forum Newbie / General discussionsReplies: 13Last Post: 9th Jun 2010, 15:17 -
DVD Slide Show Duplication
By KLouis22 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2008, 07:27 -
Best programs for .jpeg slide shows?
By Captain Satellite in forum Newbie / General discussionsReplies: 17Last Post: 30th Oct 2007, 09:50 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 12:02
