I was wondering I have a vcd the quality is good now I was wondering can I convert the vcd into a svcd? And will that make the quality better and if so what program can I use to take the vcd into a svcd thanks!
BTW what are xvcd and xsvcd are these qualitys better than standard?
You can re-encode to svcd using TMPGEnc, but re-encoding it's not a good thing, you will loose quality.
Encode directly to SVCD or xSVCD that way you will get better results.
There are guides on this site explainnig how to do that. -
Re-encoding a vcd to svcd will only loose quality, no matter what a file can never be better than its source file. Guarenteed it will look worse if you re-encode it to svcd
