I was trying to match a video clip to a dvd that is 704x480, 256 audio. I got it to work in SUPER, after trying Winff and gui4ffmpeg. When I previewed the clips in TDA 1.6, the Super was like other video I've seen - each thumbnail was "15" apart from each other. I had assumed that meant each thumb represented 15 frames per half second (you can frame-forward thru one thumb). The thumbnails for the Winff clip were 12 frames each. The gui4ffmpeg thumbnails were 18 each. Visually, the gap between the Winff thumbs was gone, whereas the gap between the gui4's thumbs were wider than the Super, so I guess that makes sense in a graphic way...but what do these numbers mean? Should I be worried about them? Is it okay to combine video that has different fame-counts per thumb? Is there a way to control them during conversion in those programs?
Example of Winff clip in TDA:
http://img444.imageshack.us/img444/1738/tdajm0.jpg
I suspect that TDA shows an image per I frame, or the first frame of each Group Of Pictures (GOP). Depending on the encoder and the settings it uses, this can be every 12, 15 or 18 frames for DVD compliant mpeg.
As far as authoring is concerned, so long the video is compliant there should be no issues.Read my blog here.
Originally Posted by spiritgummDo some reading up on what a "GOP" is (Group Of Pictures) in the Glossary (the link is at the top-left of the page). Each GOP starts with an I-frame and then has a number of frames following it - these frames are partial frames based on preceeding and following frames. That's how the file is made smaller, or compressed.Originally Posted by spiritgumm
What you're seeing is MPEG encoded with GOP lengths of 12, 15 and 18.
No. Each thumb is the I-frame from the start of the GOP.Originally Posted by spiritgumm
It's exactly that.Originally Posted by guns1inger
No.Originally Posted by spiritgumm
Yes, as long as they're all PAL or all NTSC and all DVD complaint.Originally Posted by spiritgumm
Yes, you can specify GOP lengths in some encoders. I don't know Winff or gui4ffmpeg, but have SUPER and can't see that it's possible to set the GOP length.Originally Posted by spiritgummThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
DVDStyler - please advise on menu frame count/hardware compatibility
By dogcatcher in forum Authoring (DVD)Replies: 9Last Post: 15th Dec 2011, 02:48 -
Frame count display in Media Player Classic? Or something else?
By Hoser Rob in forum Software PlayingReplies: 2Last Post: 10th Apr 2011, 10:59 -
Different Frame Count When Demuxed
By sambat in forum EditingReplies: 0Last Post: 10th Oct 2009, 18:17 -
Incorrect video duration/frame count in MKV/AVC
By crashbang in forum Video ConversionReplies: 2Last Post: 13th Oct 2008, 16:44 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
