Hello,
I have a 608 x 336 resolution video, and im using TMPGEnc to convert it.
I want to know which format, aspect ratio, etc i have to use to have a nice resolution once played in a dvd player. Im using NTSC but when i play it, the video looks shrinked.
Regards.
The resolutions for DVD are fixed, and don't reflect the proportions (Aspect Ratio) of the video, which can be either 4:3 or 16:9. 720x480 is the highest (and most common) NTSC DVD res. 608x336 is close enough to 16:9, so I'd simply resize to 720x480, with the 16:9 flag set.
If you want exact resizing, use AviSynth + FitCD
/Mats -
In TMPGEnc set the Source Asepct Ratio to 1:1 VGA, set Video Arrange Method to Full Screen (Keep Aspect Ratio). The output frame size should be 720x480, and the Aspect Ratio 16:9. That will create a 16:9 anamorphic MPEG2 file. If you prefer a letterboxed 4:3 file set The Aspect Ratio to 4:3.
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
