Hi,
I have some problems with the sound playback on certain AVI files. I have used AVICodec to figure out that they are, for example:
File: 12.87 MB (12.87 MB), Length: 0:00:36, type: AVI, 1 lydspor, quality: 94 %, CASIO EX-S770
Video : 12.11 MB, 2822 Kbps, 29.969 fps, 640*480 (4:3), M4S2 = MS ISO MPEG4 V2
Sound: 777 KB, 177 Kbps, 44100 Hz, 1 kanaler, 0x11 = IMA ADPCM, CBR
The problem is that the sound is about 1-2 seconds delayed when I play them on my desktop computer but they play fine on my laptop and a third PC! I can play other types of AVI files fine along with other video formats.
Can anyone tell me what could be the problem?
Thanks for the reply!
I have tried different players - same result.
As suggested, I tried encoding one of the AVI files as wmv on my laptop and it played fine on both computers - I then tried encoding it on the offending PC and what do ya know?!: Same result - it plays fine! Weird! I'd think that a codec problem would also cause problems when encoding to a different format... Or is that just me not knowing a thing about codecs?
I have tried installing a codec pack but only AFTER the problem occured. This resulted in player crash every time I tried to open this type of AVI file, so I uninstalled it again.
Is there a way to kill all codecs and start from scratch? Or is it unlikely to be a codec problem when I can encode the clip to wmv with no audio issues? -
Solved it!
I managed to isolate the problem to the quartz.dll file. I used MMCompView to disable and enable different codecs. It turned out I had two Direct Show video renderer codecs. I diabled one of them - and hey! It worked! -
One of the (many) problems with codec packs in particular, but even the use of many codecs on a single machine, is that inevitably some of them will clash, and it will be time consuming to track down the source. Your diligence has paid off, and I am glad you found the cause.
Read my blog here.
Dazzle for the mac xbox sound delay problems
By LOLWUTISDAT in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 01:09 -
Sound Lag/Delay with Black Magic Intensity Pro
By kILLDR3n in forum Capturing and VCRReplies: 4Last Post: 16th Feb 2010, 11:20 -
Sound delay issue after MPEG2 editing (avidemux)
By dodoecchi in forum Video ConversionReplies: 8Last Post: 22nd Mar 2009, 05:55 -
question about how to delay or advance sound/audio on DVD
By jimdagys in forum Newbie / General discussionsReplies: 17Last Post: 10th Dec 2007, 00:08 -
sound delay
By hannss in forum AudioReplies: 1Last Post: 1st Aug 2007, 16:12
