Does anyone know what the green bar at the bottom of HDTVtoMPEG means when it's different shades of green? It frequently has processing errors for me whn it hits one of these color changes.
Why this stupid program still asks me to select a channel? I just want to convert snip out part of *.ts file.
http://www.kiva.org/about -
Assuming HDTVtoMPeg2 is the program, there are different levels of ATSC streams. The full ATSC stream as broadcast can contain several sub-channels and other information identified by PIDs (Program ID). For example a channel 4 stream might have a primary and several subs. 4-1 is the primary, 4-2, 4-3 etc are the subs.
The TS file you get from a computer tuner or from Firewire on the cable box is a single video/audio pair. The tuner has stripped the single pair from the full broadcast stream.Recommends: Kiva.org - Loans that change lives.
Motorola PVR to PC use of HDTVtoMPEG and HDTV2DVD
By brillmtb in forum DVB / IPTVReplies: 10Last Post: 18th Aug 2007, 22:44
