Stupid question here which I'm hoping someone can answer since I can't find the answer either on google or searching the forums here:
Is there any currently available method of creating an avi with a standard video codec like xvid with a lossless audio codec like monkeys audio or flac for example? I know I could simply go with uncompressed PCM wav, and it may very well be my next choice if the aforementioned codes are not possible.
Thanks.
You'd have better luck with the MP4 container. It'll support ALS audio, which is lossless.
AVI formats supported:
http://www.alexander-noe.com/video/amg/#features -
Just create a 384kb mp3, which is as good as lossless. The rest is history. Or his story.
not actually lossless, but to all in tents and yurts, as good as.
PCM is too weighty, might cause bitrate problemsCorned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Deinterlacing MiniDV AVI file and saving as lossless AVI
By Dave2ic in forum Video ConversionReplies: 3Last Post: 27th Dec 2010, 16:11 -
VOB to AVI (Lagarith lossless) Audio Out of Sync
By Eva-Unit01 in forum Video ConversionReplies: 10Last Post: 17th Aug 2010, 10:50 -
Is an .avi lossless in this instance?
By Anonymous4374945 in forum EditingReplies: 12Last Post: 30th Sep 2009, 16:22 -
AVI - Lossless Trimming
By tripecac in forum EditingReplies: 14Last Post: 4th Jul 2008, 03:03 -
Non-interleaved?
By KingBongo in forum ffmpegX general discussionReplies: 0Last Post: 11th Jun 2007, 07:47
