I'm using of of those $30 special Pinnacle PCTV Pro's to capture, and althouhg I am hardly dropping and frames, the video jerks around in medium to high motion scenes (suck as a slow pan with lot of people walking around). Is there any way I can allieviate this? I can use virtually any capture program, although I personally like virtualdub, so all tips apply for all capture software. Thank you all for the help!
AthlonXP 1.4Ghz (1600+) on MSI K7T266Pro2
512 MB OCZ PC2400DDR (2x256)
Dual WD400BB's in RAID 0 on EPOX RAID card
WD153BA capture drive (primary Master)
Teac 512EB(Secondary Master) Toshiba 1612 16x DVD (secondary Slave)
Radeon 8500 Retail
Pinnacle PCTV Pro
Soundblaster Live!
Windows XP (althouhg I also have Windows 98, and ME, so I can install those for a dual/tri boot if necessary)
I have almost the same system, PCTV Pro, AMD 1600 XP... no RAID configuration though.
If you are not dropping frames, then I suspect what you are noticing are the artifacts (or limitations) of 30 fps video/inverse telecining, or perhaps the limitations of mpeg compression. For instance, I have one scene in particular that is a slow pan. I've noticed that the AVI file displays it properly, but it is not nearly so smooth after mpeg encoding.
Darryl -
Actually, the avi files display this same error (pre-MPEG1 comversion). Thanks for the post though!
I had a similar problem caused by the interlasing field order, stills were fine but motion was very jumpy and even hurt the eyes to look at it.
In TMPEnc under Settings - Advanced - Field Order - change to the opposite setting from your current (either top or bottom).
Or when capturing in Virtualdub under Video - Format. Set the other field to be first.
May not be your problem but worth a try.
Chris.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 05:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 13:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
