Please someone help me!! lol really, i do need some help here..i have 30 episodes of a tv drama series that i would like to burn onto DVDs. I was hoping to merge at least 2 episodes on each DVD disc. All the episodes were in VBRM format originally and i use WINAvi to convert all the episodes into DVDs. Now i don't quite know the next step. Is there a program out there that allows for merging 2 episodic DVDs onto one disc? Preferably a program that will know how to structure the VOBs and VTSs files. Please i would appreciated any help. Thanks!!
How long is one episode?
You can usually fit ~2 hours on a DVD-5
And do yourself a favor - forget about WinAVI. If you want some simple but working solution, use convertx2dvd.
Mats -
There's a number of ways you can do it. I'll presume that there's no pre-existing menus you want keeping. If there is, then DVDRemake contains the most painfree merge of DVDs I've ever seen - it's literally a three-click operation and retains everything the way it should.
However if you want to make your own menus, then there's a couple of ways to go about it. I would use TMPGEnc DVD Author, and import each title (VOB set). Then you can create your own menus within the program and output a DVD ready to burn. Or if menus aren't important, you can use DVDShrink and literally just drag titles to the reauthor window. It is then up to you as to whether you let DVDShrink shrink anything.If in doubt, Google it.
Need to burn TV episodes to DVD
By harishkumar09 in forum Authoring (DVD)Replies: 44Last Post: 3rd Mar 2013, 06:35 -
method merging two dvd movies
By asif shafiq in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2010, 05:03 -
DVD episodes to MPTS
By waveqam in forum Video ConversionReplies: 3Last Post: 15th Apr 2009, 17:37 -
Merging the contents of 2 DVD into 1
By txl in forum Authoring (DVD)Replies: 4Last Post: 7th Oct 2008, 09:24 -
How do you author many episodes to 1 DVD-R?
By 1980sumthin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2007, 23:49
