    Mar 2007
    Singapore
    Help!! when i wanted convert my rmvb, it keep getting hang.. when i choose the file i want to convert, it pop out the window that can choose the type of video i want to convert to but after i click it just hang.. why? i tired other video, it can work.. only rmvb file it don't work.. can someone help me?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Tried something besides TVC? Like SUPER or convertx2dvd? What do you want to convert to?
    Mats
    Mar 2007
    Singapore
    i tired others b4 but it need a long time to convert.. and tvc is the fastest so i prefer using tvc.. i wanted to convert from rmvb to avi so that i can burn into a vcd and watch on my home tv..
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, I'd prefer a slow tool that works, over a fast one that doesn't...
    But "convert from rmvb to avi so that i can burn into a vcd " - Why take the detour over AVI? If SUPER can at all open your RMVB, it can convert to VCD mpg in one go, which should more than well make up for it's lack of speed (which I've never heard anyone complain on - on the contrary!)
    /Mats
  5. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    If you have RealAlternative installed you can try to change settings from 'Always use internal decoders' (default) to 'Try to use DirectShow' - accessible from the tab where compression types are selected.
