Results 1 to 11 of 11
    Apr 2007
    Greece
    I have created a slide show file (slideshow.vob) with DVD-slideshow and need to convert
    it to mpeg4 I think in order to burn it on dvd. Is there a program that can do that job ?
    I believe it can be done with transcode but couldn't find out how.
    Your help would be most welcome.
    Theophanis
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    No, no, no. mpeg4 has nothing to do with Video DVD. VOB does, and can be demuxed into the components real authoring apps would expect:
    http://www.linuxquestions.org/linux/answers/Applications_GUI_Multimedia/DVD9_to_DVD5_guide
    Specially item 3 may be of interest.
    /Mats
    Apr 2007
    Greece
    Thanks Mats for the info.
    I followed the instructions and works OK .The only problem was that when
    tried to multiplex the .m2v and .ac3 files got the error msg " can not read
    from xxxx.ac3 file". Burned the project on a DVD and can play it but without sound.
    Any idea what the problem might be ?
    Has to do maybe with the type of audio file I used when creating the dvd-slideshow ?
    When running the xxx.vob slide show file on Kmplayer works fine.
    Theophanis
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Probably there's no AC3 stream in your VOB, no.
    What audio stream is there?
    /Mats
    Apr 2007
    Greece
    The audio file is .wav type. DVD-slideshow supports at the moment mp3, ogg and wav formats.
    About the stream you are asking I am not quite sure if above information will be of help.
    I guess I have to do some reading concerning the AC3 stream subject .
    Theophanis
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    DVD-slideshow surely converts the audio (since neither mp3, ogg nor wav is DVD audio) to some DVD compatible format. These are mp2, AC3 or LPCM.
    /Mats
    Apr 2007
    Greece
    You are right.
    Reading the manual of dvd-slideshow I see following :
    "... [-mp2] Use mp2 audio by default. AC3 audio seems to be more stable
    when playing in dvd hardware players, but requires ffmpeg. This
    will over-ride the AC3 default and use the mp2 audio encoder. "
    Since I didn't use the -mp2 option when creating the slide show the stream audio must be AC3.
    To extrtact the .ac3 file from the .vob I used the command
    " tcextract -i xxxx.vob -x ac3 -t vob>xxxx.ac3 "
    From what I read on the manual of tcextract the command must be correct.
    But the created .ac3 file is indeed empty. Any idea why ?
    Theophanis
    P.S. Thanks for your help Mats so far.
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    No idea, really. Isn't there any command in the transcode library to list available streams i a vob? tcprobe perhaps?
    You could also try tcdemux
    http://www.transcoding.org/cgi-bin/transcode?Tcdemux
    tcdemux -i xxxx.vob -x ac3 > xxxx.ac3
    /Mats
    Apr 2007
    Greece
    Dead end . Couldn't find a command in transcode to show available streams in .vob
    tcdemux didn't work either.With tcprobe got following , but means nothing to me
    tcprobe -i olympos.vob
    [tcprobe] MPEG program stream (PS)
    [tcprobe] summary for olympos.vob, (*) = not default, 0 = not detected
    import frame size: -g 720x576 [720x576]
    aspect ratio: 4:3 (*)
    frame rate: -f 25.000 [25.000] frc=3
    PTS=0.1847, frame_time=40 ms, bitrate=7500 kbps
    audio track: -a 0 [0] -e 48000,16,2 [48000,16,2] -n 0x50 [0x2000] (*)
    PTS=0.1847, bitrate=128 kbps
    -D 0 --av_fine_ms 0 (frames & ms) [0] [0]
    Will try create the slide show again with option -mp2 and see if it works.
    Theophanis
  10. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Did you try
    or
    tcdemux -i xxxx.vob -n 0x50 > xxxx.ac3
    (The -n 0x50 is from the tcprobe output:
    audio track: -a 0 [0] -e 48000,16,2 [48000,16,2] -n 0x50 [0x2000])
    /Mats
    Apr 2007
    Greece
    I had used
    tcdemux -i xxx.vob -x ac3 > xxxx.ac3 and didn't work.
    I tried now also
    tcdemux -i xxx.vob -n0x50 > xxx.ac3
    but still doesn't work.
    I have create a new (smaller) dvd slideshow and used the option -mp2 for the audio
    just to check it, and when I did tcextract -i xxx.vob -x mp2 -t vob > xxx.mp2 it worked fine.
    The xxxx.mpg file works fine also. Haven't burn it yet on a dvd to see if it plays OK on my
    dvd hardwear player though.
    Theophanis
