Please consider supporting us by disabling your ad blocker or buy PlayOn and record Netflix! :)
Results 1 to 9 of 9
  1. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    I have just Hooked up my Soundcard Creative Live to My RXV 800 Amp using a Coax cable and a Mono 3.5mm Jack.
    The only sound I can get is PCM Stereo Im using the latest VLC program and have played with the settings and it still does not work can anyone suggest anthing I have tried about 5 Different x264 files and they all do the same thing
    I have it hooked to number 7 on the left hand side
    http://www.superfi.co.uk/images/RXV800rearlg.gif
    plugged in the orange plug
    http://www.adam.com.au/foaley77/IMG_2838.JPG
    http://www.dse.com.au/cgi-bin/dse.storefront/461b7a3b0b35b1ec2740c0a87f9c071e/Product/View/C1706
    http://www.jaycar.com.au/productView.asp?ID=PA3500&CATID=&keywords=rca+mon&SPECIAL=&fo...Max=&SUBCATID=
    Dec 2004
    Australia
    x264 is a video codec, it has nothing to do with audio. What is the audio format?
  3. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    codec : AC3 5.1
    bitrate : 640 kpbs
  4. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    A normal dvd does not work either
  5. Member thevoelk's Avatar
    Sep 2004
    Forest Hill, MD
    To get my HTPC working, I had to go into the Creative Mixer, then to Settings, then playback, and then check the box that says "Digital Output Only". It may be my receiver, but the volume seems a lot lower than from other sources. Hope that helps.
    Dec 2004
    Australia
    Had a look at VLC and I don't see any S/PDIF output setting. You might need to use a different player such as mplayer which like VLC uses internal decoders.
  7. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    I have all ready done this
    VLC has S/PDIF When I use it the Amp brings up Digital but the sound skips what does this mean?
  8. Useful Idiot Phlexor's Avatar
    Jun 2001
    Rowville, Victoria, Au
  9. Member foaley77's Avatar
    Jan 2002
    Adelaide ,Australia
    Cheers Mate
