Better title would be what NOT to stop for XP
As we said earlier, all Win9X based systems are easy. Just use cntl-al-del and stop EVERYTHING except EXPLORER.
XP is a bit different.
Here is what I have found.
Do not stop the following
DEVLDR32.EX or TASKMGR (Its what your using for CNTL ALT DEL)
EXPLORER
ALL SVCHOST's must stay
SYSTEM and SYSTEM Idle must stay
Non-stoppable critical
LSASS
WINLOGON
CSRLSS
SMSS
Lastly, NACAPSVC will not stop as I THINK it is a NORTON nav file hook tied to the new SVC call.
After stopping all but the above, I was able to view files, opened and used MYFLIX, TPMG and ULEAD.
One note I found interesting. If you look at the performance tab on TASK MANAGER BEFORE stopping, you get an occassional spoke, but mostly flat line. After stopping all else, it went into DEFIBULATION (LOL) and had a steady sine wave pattern. That says to me something was looking for something else (steady polling).
Hope this helps some folks. At least you KNOW now what NOT to stop so you don't get the dreaded built in message that your system will now shutdown in 45 seconds and please logoff.
for me, based on hear-say,
I'll stick with windows 98 for
a another year or so. I'm
sure xp will be requireing some
thing like 128mb of ram, which is
all I got (and need)
You can keep hte bells and whistles
ie, colors, pictures, desktop look
etc.
-vhelp
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 13:30 -
SOLID ANSWER: .Tivo to .MPG or MOV
By DarkPhoenix77 in forum MacReplies: 24Last Post: 5th Feb 2011, 17:43 -
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 09:38 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 03:54 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 21:42
