I have an MKV with h264 video and AAC 5.1 audio track.
I use Media Player classic or Zoom player to play all my videos.
I can play the video ok ....but I dont seem to get 5.1 sound.
Anyway of getting the AAC 5.1 sound???
I have my sound card (has ADI 1988a codec... which is HD Digital audio)
outputing via an optical outlet to my AV 5.1 receiver.
I have AC3 filter installed.
I am only getting 2ch audio at moment....how to get 5.1 sound????
For optical you need AC3 or DTS for 5.1. So unless your sound card supports DTS connect or Doly Live, then you need to enable software AC3 encoding. I believe AC3 Filter can do that. As can ffdshow. ffdshow is probably best since it can also decode aac.
You could also use 6 channel analogue.
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 08:41 -
Decoding MPEG-4 HE-AAc v2 audio in Stereo from DVB-T Broadcast
By tolinn in forum DVB / IPTVReplies: 0Last Post: 10th May 2010, 11:49 -
AAC 5.1 to AAC 2ch conversion problem
By MR 3 in forum AudioReplies: 6Last Post: 2nd Feb 2010, 22:44 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58 -
Playing a h.264 aac MKV file with PowerDVD 7.3 nvidia purevideo installed
By maxpower2078 in forum Media Center PC / MediaCentersReplies: 6Last Post: 28th Jul 2008, 07:48
