guys new to the group, purchased a toshiba D-R4 recorder about one month ago. Have not had any problems with till yesterday. I was copying a vhs to dvd and got an alert message. tried it again today and the same thing happened. Tried to copy a tape which I already copied once using this recorder and got the alert again. Any suggestions what could be wrong. Hope you can help out.
holytrain
what is the message?
Thanks for the reply, the only thing it says is alert. now the manual says that when you try to copy something that is protected you will get that message. when I do make a backup copy of a protected video I use a color corrector to take out the macrovison. This has worked fine in the past with makeing copies of vhs & even dvd's. I guess I'm sorta lost to try to figure out what to do next.
Thanks again.
holytrain -
this is a common problem even on some non macro'd tapes ... i dont remember the solution other than using a TBC ... but several threads here on that very subject
Sr-w5u auction alert!!!
By jbd5010 in forum Capturing and VCRReplies: 166Last Post: 16th Apr 2013, 11:19 -
Is there any way to prevent/alert webcam recording?
By drug3188 in forum Video Streaming DownloadingReplies: 9Last Post: 3rd Sep 2009, 01:49 -
windows defender alert
By black cloud in forum ComputerReplies: 5Last Post: 14th Jan 2009, 21:49 -
red alert in videoredo plus
By sumeshkri in forum EditingReplies: 3Last Post: 11th Feb 2008, 23:35 -
Toshiba Error E-25 Message
By anichan in forum DVD & Blu-ray RecordersReplies: 5Last Post: 21st Oct 2007, 23:48
