Results 1 to 14 of 14
    May 2004
    CANADA
    how can i split the file or shorten it so i can use it on 2 dvds, do i have to split in half or anywhere i want?
    also when ulead tries to shrink it i get this error message "convert step stopped got some problems"
  2. Member daamon's Avatar
    Melbourne, Oz
    Use VirtualDub - it's free. Also, make sure that Video -> Direct Stream Copy is ticked.
    There's also AVCutty, also free, but I don't know how good it is.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    May 2004
    CANADA
    what am i doing wrong the split file is huge!!!!
  4. Member daamon's Avatar
    Melbourne, Oz
    Otherwise VirtualDub defaults to uncompressed AVI which is, as you've found, huge.
    Carpe diem.
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I believe that's a bug in the program, make sure you have the latest updates.
    The newer versions will let you export the video as files, look in the manual.
    May 2004
    CANADA
    wat are the steps i should do.?
    the file was like 20gb
  7. Member daamon's Avatar
    Melbourne, Oz
    It'd help if you said which tool you're using...
    Carpe diem.
  8. Member daamon's Avatar
    Melbourne, Oz
    Set your in and out points - i.e. where you want to cut the file. Outside of these points won't be saved.
    Then save the AVI.
    Repeat with different in and out points until you get the whole original into various chunks as files.
    A good place to always look is at the guides listed underneath the tool. Go to VirtualDub's entry in the Tools section by clicking on the VirtualDub hyperlink. Scroll down and, voila!, there's a guide titled "How to cut an AVI file in smaller parts".
    Carpe diem.
  9. Member Cornucopia's Avatar
    I STRONGLY recommend that you also save an additional copy of the UNCUT audio track(s).
    There often is a glitch at edit point for cut & re-merged audio; you can always do both and use the cut tracks as reference to sync the uncut back up with the video once you're ready to re-merge.
    You can also just load your file into Vdub, set outputs as "Direct Stream Copy" (both A+V) and "SAVE AS SEGMENTED AVI". That way you won't have to take the time to set edit points, it'll do it automatically according to frame or MB Max settings in the ouptut/save dialog.
  10. Member daamon's Avatar
    Melbourne, Oz
    Cool! I've never noticed that. "You learn something new every day..."
    Carpe diem.
    May 2004
    CANADA
    but what do u click so it can choose are a poin to cut it in the middle?
    May 2004
    CANADA
    ok i split the dvd, but even before i split in when i try to burn it in dvd moviefactory 5 i get the error "convert step got some problems"
  13. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I suspect you have two different problems.
    Is the 20 GB file a DV avi file ? If so, it is only 80 - 90 minutes, which will easily fit on a single DVD. You just have to use the right bitrate when you encode.
    However if you are getting the same error out of Ulead before and after splitting, then I suspect that problem is caused by something else. Try Ulead support. Check their knowledgebase, make sure you are patched to latest version, and try again.
    Read my blog here.
