I have many MP3s that I have converted to WAV files of which I am cleaning up.
I intend to convert the WAVs to MP2s to put on DVDs.
If I encode the WAVs to MP2s at 192kbps, will the quality of the music be as good as MP3s at 192kbps?
I'm asking because I'm wondering if I need to preserve the quality of my work for future DVDs, ALSO as MP3s.
I hope my question is clear
Thank you
No, as MP2 is not as complex as MP3, it's also not as "efficient".
For "192kbpsMP3-quality", I'd expect to have to make the MP2 bitrate = 224 or 256kbps.
Note: It's not totally linear, so at the top bitrate end both codecs are more similar, at the bottom end MP3 has a much bigger advantage.
Scott -
I'd strongly recommend re-encoding your original audio sources to a dvd compliant audio format - preferably lpcm or ac3. Going from mp3-wav-mp2 will not help quality. Now if you mean static only then yeah it will probably help a little.
But audio is just like video in that going from one format to another tends to reduce quality with each generation you move away from the original source. So you'd be best to start from scratch. Just my two cents here.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thank you guys
My originals are MP3s and I do have to edit out a lot of noise, so I will have to do 2 conversions
It looks like you guys are saying that would be better to convert the WAVs to AC3s instead of MP2s.
And.....that I sould ALSO preserve my WAV work as highly encoded MP3s
Another reason MP2 needs a higher data rate is that MP2 uses 48 KHz sampling rate vs 44.1 KHz for MP3.
44.1Hz --> 48kHz is only an ~8.5% markup, which would require a bump in bitrate from 192kbps to 207kbps, so not quite the comparison I was thinking of.
Although, BTW, both MP2 and MP3 can operate at either 44.1 or 48k. You're probably right in assuming, though, that a conversion from CD/WAV would normally be 44.1 and DVD use would require 48k.
MP3 @ 44.1kHz --> PCM @ 44.1kHz --> PCM @ 48kHz --> MP2 @ 48kHz
isn't very different from
MP3 @ 44.1kHz --> PCM @ 44.1kHz --> PCM @ 48kHz --> AC3 @ 48kHz
except the AC3 is a little bit better quality at same compression, and is more universally compatible for DVD players.
how to convert mp2 audio to lpcm?
By gareth41 in forum Authoring (Blu-ray)Replies: 9Last Post: 21st Oct 2011, 13:47 -
MP2 audio with LAME?
By RogerTango in forum AudioReplies: 7Last Post: 3rd Nov 2009, 22:28 -
Extract audio from MP2 and more
By txl in forum AudioReplies: 7Last Post: 30th Jul 2009, 06:49 -
aiff to mp2 audio conversion problem...
By huatnee in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 11:52 -
What software should I use to extract DVD audio and convert it to mp3s?
By maccaneer in forum MacReplies: 2Last Post: 4th Sep 2007, 18:03
