I think I've got my facts straight here, but let's just say I'm using my Sony Digital 8 camcorder to play back an 8 mm tape via the DV FireWire output and into my computer.
Now: Regardless of what kind of DV profile I select with Scenalyzer, and regardless of what DV codecs I might have installed on my system — the DV stream in this case is coming from the camcorder and has nothing to do with anything else, correct? In other words, the Sony is creating its own DV stream with its own codec and simply transporting that to my computer. So, the stream will always be the same regardless of one's computer or configuration.![]()
I think that's right, but I just was hoping someone would confirm/disconfirm it for me.
By the way, I'm not concerned about further rendering of the "captured" DV file - only the video stream coming from the camcorder.
Originally Posted by echo1434
The capture program needs to decode the DV video for preview, or in the case of Scenalyzer, for "optical" scene break analysis. To do this it will use the DirectShow MS-DV or other codec. This should not affect the data stream being captured/transferred to the hard drive.
what codec should I use for editing camcorder dvd ?
By codemaster in forum EditingReplies: 0Last Post: 25th Dec 2011, 05:34 -
camcorder dvd to quicktime avid dv codec
By codemaster in forum EditingReplies: 3Last Post: 17th Dec 2010, 09:45 -
complete camcorder virgin looking for a (up to)$850 camcorder
By rocketman122 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 28th Aug 2010, 10:34 -
Camcorder with native codec compatible with windows?
By sgparkin in forum Newbie / General discussionsReplies: 10Last Post: 8th Nov 2008, 14:03 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:47
