I know we can do it with virtualdub, but when joining parts again there's always a remarquable picture "jump" on the joined points.-
Is there any other way to do it ??
hilario.
you can overlap sections of a cut - which is a common edit technique (though the "fast cut" is more common right now) .. you can do this with any NLE software or with avisynth ..
Maybe this will help:
https://www.videohelp.com/tools?tool=SolveigMM_AVI_Trimmer -
Originally Posted by hilario
Originally Posted by jagabo
I selected the beginning and the end of the part I want to cut.
Next segment I select the beginning exactely at the same point where the first one ends.!!!
Is this a wrong way to do it ??
hilario. -
Be sure that the cut point is a key frame. Say for example frame 10,000 is in the middle of the file and is a keyframe. Mark-in at 0, mark-out at 10,000. Save that section (note that frame 10,000 is not included in this file). Then Mark-in at 10,000 and mark-out at the end of the file. Save as AVI. The two resulting files will join perfectly. Always works for me.
Split AVI
By niol1000 in forum ProgrammingReplies: 1Last Post: 9th Jun 2010, 17:49 -
AVI Split - The right way?
By B11 in forum Video ConversionReplies: 1Last Post: 25th Dec 2008, 13:47 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
split one file avi in two
By Jomapil in forum Newbie / General discussionsReplies: 4Last Post: 8th Mar 2008, 14:13 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
