hi! just have a little question, when I select the output size, i select target quality 100%, but when I compare the created file to the original one, the quality is not as good. so, which option should I select to create a file of the same quality? thank you very much!
Hi-
You can't. Encoding for AVI is lossy. You're guaranteed to lose quality. If you're not satisfied with 100% quality, it won't get any better than that using AutoGK. Well, maybe it will, if you're willing to increase the resolution. Using a custom quant matrix and encoding manually is about the best way I can think of to approach the original DVD quality when encoding to AVI. -
@Likkletisha: Please dont hijack threads! Start your own for a new question or topic.
Mats
DGIndex says 100% Video, but MeGUI Avisynth analysis says Source Type Film
By Simcut in forum DVD RippingReplies: 11Last Post: 9th Mar 2012, 16:10 -
AutoMKV vs AutoGK (xvid encoding quality)
By dphirschler in forum Video ConversionReplies: 27Last Post: 7th Sep 2011, 11:43 -
Getting bad quality with AutoGK
By alc112 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Aug 2010, 08:37 -
AutoGK - Bigger file = better quality?
By kelemvor in forum DVD RippingReplies: 13Last Post: 8th Jan 2008, 22:15 -
AutoGK error with DivX, The source image format is not acceptable
By 2dpikke in forum DVD RippingReplies: 2Last Post: 19th Jun 2007, 03:31
