Hi
I'm doing some testing with this application, which I've just obtained.
Using my short test [PAL] AVIs, everything progresses well until bbMPEG is scheduled right at the end. I then get an error saying
"Input file ..\..\Pulldown_Encoded_Video_NTSC.mpv was not found"
This file is indeed absent, as I would expect in a PAL compilation. (The nearest likely equivalent is a file called"...CCE_Encoded_Video_PAL,mpv", which is there.
The program proceeds after clicking OK to close the error dialog, and reports that an image has been created. None has.
Does anyone have any ideas or tips?
-Pete
Sounds like a bug...
Try and figure out what your encoded video and audio files are and mux them manually in BBMPEG or TMPG. -
It seems to be a bug since I experienced the same when I tried to convert my PAL video. Manually multiplexing with TMPGEnc did the trick.
However, I was disappointed with the quality. How are your results? I converted a DVD earlier and was impressed with the quality. Since I didn't seem to manage to get the CCE parameters right I hoped that this AVI to SVCD function would help me converting my own digital video AVI files (DV-AVI). But I got actually worse results
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 08:28 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48
