Every time I use the "Play on my" feature that comes with my 3d Fuzion (Nvidia Geforce 4000 MX), my PC monitor changes to a smaller resolution and the refresh rate goes down to 60 Hz. Is there a way to keep my monitor settings when using TV out?
Monitor: Compaq S710
Video Card: Nvidia Geforce 4000 MX (with latest drivers)
PC stats: Asus P4P800S 2.6 gHz PIV CPU, 512 MB RAM, 80 GB Maxtor, 120 GB WD SATA, 13 GB WD.
In 'Control Panel>Display>Settings' does it show two monitors? You should be able to set your TV or secondary monitor to one setting and your primary or computer monitor to a different one. Your TV and computer monitor may need to be both hooked up and running when you do this. Otherwise, you may just see one monitor.
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
Help!! PC Monitor Won't Reset To Factory Settings.
By Aaron1927 in forum ComputerReplies: 1Last Post: 29th Dec 2008, 11:30 -
Monitor settings (on Emachines 17" CRT Screen)??
By willhenderson in forum ComputerReplies: 12Last Post: 14th Dec 2007, 10:40 -
DLP Monitor settings for live shots
By NutsaQer in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 22:33
