Philips dvd5960/37 need Manual
I just bought this on ebay Does anyone have a manual i can t download it from philips website for some reason. the ie explorer just quits. I got the firmware update.
so I need a manual please,
how to install firmware upgrade,
how to use the usb??
what universal remote is good for it
right now i got a usb cable connected from the player to my modem
do i need a usb cable from the back of my pc to the player?
help I could use thanks
Results 1 to 10 of 10
k got the manual finally downloaded and thanks for the link
How to I apply the firmware upgrade???
and
can I files from my fat hardrive with a usb cord?
I don t know how this usb works help please -
Not a clue about the firmware upgrade but your other problem should be answered in this thread - https://forum.videohelp.com/viewtopic.php?t=301465
He's a liar and a murderer, and I say that with all due respect. -
thanks for the Phunkyfish link its great answered alot of question
both of you thanks for the help, got the manual, and firmware upgrade is on
Now what i need to know is how to get it to read my hard drive using usb
its a 140 gig westerndigital fat 32
and
how to connect the usb cable???
do i plug the player in and the other end in my pc usb slot?
what hard drives are supported, anyone know -
I might be wrong but I think the hard drive has to be in an external enclosure. Read the topic I linked to, there's LOADS of info' regarding hard drive compatibility.
your right from what i have been reading, the external harddirve needs to plug in and then it can be used along with an assorted of thumbs and flashdrives. But what a player eh. Just doing data cds that takes seconds then to watch a movie right away no burning for 2 hours. This is awesome
thanks for your help Happy Easter -
The drive has to be formatted with the FAT file system (FAT16 or FAT32), NTFS won't work. Many drives that get their power from the USB cable won't work because the 5960 doesn't supply enough power. In those cases you'll need an external power supply.
There are like 500 posts on this, try searching the board first:
https://forum.videohelp.com/viewtopic.php?t=301465&highlight=5960
https://forum.videohelp.com/viewtopic.php?t=313992&highlight=5960
ffmpeg Manual
By cobra505 in forum ffmpegX general discussionReplies: 7Last Post: 20th Jan 2013, 01:03 -
lost without manual
By MTF123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jul 2010, 08:35 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
HELP phillips dvd5960/37 hdmi to dvi
By mobstatus in forum DVD & Blu-ray PlayersReplies: 7Last Post: 27th Mar 2008, 00:51 -
Owner's Manual
By golfnut in forum DVD & Blu-ray PlayersReplies: 4Last Post: 17th Jun 2007, 12:37
